ssenpi
Feb 10, 2023Follower
Cant change 3rd octet
I'm trying to set my ending IP to 10.0.255.254 but its not allowing me to make any changes to the 3rd octet. I have set the appropriate subnet mask but when I go to edit the 3rd octet it just stays a...
Feb 10, 2023Guru - Experienced User
Why are you trying to change the Subnet Mask and 3rd Octet? Your 255.255.0.0 SNM is a B Class network and would not be supported on a C class network. Does 10.0.0.2 starting IP address not work?
Doesn't default 192. and subnet 255.255.255.0 not work?
