mikez0r
Sep 15, 2021Tutor
Cant connect switch to XR100 wifi
For some reason, i still cant connect my switch to wifi. I have been at this for months now and still no solution. Nintendo says its the ISP, then ISP says its netgear. Just going arounds in cirlces....
Netduma-Liam
Sep 16, 2021NetDuma Partner
Does the Switch show up in Device Manager? If you change it's Device Type to something else, like Games Console, are you then able to access the internet on it?
mikez0r
Sep 16, 2021Tutor
It does show up in device manager. I tried changing the device name and device type but still nothing. I’ve been told that it’s blacklisted, how do I remove that?
- Netduma-FraserSep 16, 2021NetDuma PartnerIf it's been blacklisted then it sounds like Nintendo has banned the switch entirely from going online, in which case that's not something we can help with. Can you connect to the WiFi on your ISP router? If that doesn't work it's not the XR at fault and at that point I'd recommend taking it to a friends or somewhere you can use WiFi and see if it works. If it doesn't then it's the Switch itself and you may need to follow some other troubleshooting steps online or figure out whether it is banned e.g. did you buy it second hand, did you use illegitimate software on it etc.
- mikez0rSep 16, 2021TutorSo I am able to connect to wifi (router), but not fully connect to internet. I’ll start with that the switch is only 3 months old, bought from target in store. I used to have a spectrum modem and router and it would connect without any problems. Then got the Netgear modem (cm2000) and router (xr1000) and the switch stopped working. I am able to take it to my Dads, brothers, other brothers and connected to wifi with no problems.
- Netduma-FraserSep 16, 2021NetDuma PartnerOkay great thank you for clarifying. Does it have any sort of message or error when it tries to connect to the internet but can't?
Do you have Armor enabled on the XR? Try disabling QoS fully from the Congestion Control 3 line option menu and see if that allows you to connect. Have you added the Switch to the Geo-Filter?
