Bseyferth1294
Sep 04, 2018Aspirant
Cant connect to a xbox live party
I have the xr500 router with my xbox one x hardwired into it. I cant connect to live parties, but when I disconnect it and connect to live through WIFI I can connect. Is it possibly a setting I have s...
Netduma_Jack
Sep 05, 2018NetDuma Partner
Do you have the Geo-Filter enabled and set to Filtering Mode? This may be blocking the party server. If this is happening, please read the Allow & Deny section at the bottom of this guide on how to whitelist a connection: http://support.netduma.com/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter-setup-step-2-
If Geo-Filter is not being used or in Spectating Mode, you may not have an open NAT. Could you read this guide please:
http://support.netduma.com/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-nat
- Bseyferth1294Sep 05, 2018Aspirant
I do have Geo-filter enabled and set to filtering mode. When I have it hardwired and test my NAT type via xbox, it says it can't find Teredo IP adress, but when im wireless is has open NAT type. Could that be my settings or my internet?
- Netduma_JackSep 06, 2018NetDuma Partner
I think that's probably where your issue lies. Did you give your Xbox a static IP address? It's possible that it's unable to connect to the router because it doesn't have a dynamic IP address.
You can check this on your Xbox by going to your Xbox One's Dashboard. Navigate to Settings > All Settings. From there, choose Network > Network Settings > Advanced settings and make sure you have a dynamic IP address selected.
Afterwards, set your Geo-Filter to Spectating Mode and hard reboot your Xbox. See if you can then join party chats. If you can, then set your Geo-Filter back to Filtering Mode.
