Huthayfa
Jul 16, 2018Guide
XR500 QoS, UPnP issue with VLAN tagging.
Hi,
recently I have got my XR500 with DumaOS. I discovered an issue, I am using fiber connection that requires VLAN tagging on WAN to get the internet working. when I put my fiber ONT in full brid...
- Aug 30, 2018
this issue has not been fixed yet, and guess what? seems like there is no fix at all.
for everyone else having VLAN setup, be careful while cosndering the XR500 for your setup since you will find some main feaures not working properly.
thanks.
Jacksonite
Sep 05, 2018Aspirant
I am having very similar issues with certain devices and media not playing. However as soon as i turn off the QOS every device and media works. Technical support is currently working on a new firmware. I am still waiting for them to call me back. I wonder if they fixed this issue on the xr700.
Netduma_Jack
Sep 05, 2018NetDuma Partner
Hi Jackson - are you using a VLAN setup too?
I wouldn't have expected a total shutdown though. Do you have Share Excess enabled on Bandwidth Allocation? Also make sure you haven't set Anti-Bufferbloat percentages too low. This guide will help: http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos-step-3-
