dxtNET's avatar
dxtNET
Can't connect to Australian nbn with xr500
Hi, i'm having issues connecting to my nbn network with my xr500 gaming router, currently i'm using a TP link TL-WR840N and that connects fine, i've updated the firmware to the lastest version which ...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Apr 07, 2020
    Yes you're probably right in that you'll need to setup VLAN before you can sustain a connection. Also make sure that you're using 'Always Connect' for PPPoE in Internet Setup. You can go to Settings > Advanced > VLAN / Bridge Settings for VLAN. What you'll likely need to do is select 'By VLAN Tag group' and then edit the existing internet VLAN rule.
