MrTwisties
Jun 24, 2018Aspirant
Can't connect with old modem/router in bridge mode
Recently bought a fancy new XR500 and want to put my old Archer CR700 into bridge mode so it functions exclusively as a modem. Unfortunately, every time I do that the router loses its connection t...
MrTwisties
Jun 25, 2018Aspirant
Thanks Jack
This struck me as being quite similar to the initial installation process (power everything off, then turn the modem back on first and finally the router), which I went through a few times before posting here. Sure enough, trying it again hasn't made much difference!
I think I'll go out and pick up a new cable modem, see if that helps.
Netduma-Fraser
Jun 25, 2018NetDuma Partner
If bridge mode isn't working then instead of purchasing a new modem put the XR500 in it's DMZ. Disable any port forwards/UPnP on the Archer and keep wifi disabled on it.
