Homer99r
Mar 31, 2019Follower
Can't connect Xbox One X (wired) to XR500 router
So I just bought the XR500 router and tried to connect it to my Xbox One X using ethernet cable, but was unable to. I have the lastest firmware (v2.3.2.40) btw. On the Xbox network settings while try...
Netduma_Jack
Apr 02, 2019NetDuma Partner
I think you found the problem - the static IP you have put on your Xbox is most likely not correct for your new router. Can you change it back to automatic (dynamic) on your Xbox and see if that fixes your problem.
If not, please let us know your network settings on your Xbox and we can take a look
