grumpy_squirrel
Mar 12, 2022Follower
Can't disable XR500 DHCP server
Router model and DumaOS version: XR500 V2.3.2.130 I just bought a Firewalla Blue+, which requires my router DHCP server to be disabled for compatibility, so the Firewalla can operate in DHCP mode. ...
Netduma-Fraser
Mar 13, 2022NetDuma Partner
Have you given the device you're changing settings on a reserved IP on the router or the device itself? It's likely done that because you wouldn't be able to access the interface otherwise. Once you've set it then disable it and see if it saves.
