3ijtKwij
Aug 08, 2019Initiate
Can't do anything on DumaOS with XR500
Hi everyone Somehow recently when I try to access my admin panel (DumaOS) I see the actual content for a few seconds and then it changes to the following message: You are no longer connected to ...
Aug 08, 2019Guru - Experienced User
What browser are you using? Try FF or Opera.
Wire or wireless connected to the XR router?
Netduma_Alex
Aug 08, 2019NetDuma Partner
Try your browser's incognito mode/private browsing mode. If this works, you can clear your browser's cache and this should fix the problem.
