LaDr
Aug 18, 2024Aspirant
Cant enable scheduled WIFI on XR1000
Hello , why am i not seeing end time? Cant seem to get this to work..... Trying to scedule wifi on/off.. Best regards Lars
LaDr
Aug 19, 2024Aspirant
Tested Safari , Chrome, Edge and FireFox ... same ...
Try an update then...
Aug 19, 2024Guru - Experienced User
FW should fix that...
- LaDrNov 21, 2024Aspirant
No, sorry, fw didnt fix it.. đ
- Netduma-FraserNov 21, 2024NetDuma PartnerMake sure you're accessing the interface using HTTP - not HTTPS - in some cases the browser may be forcing HTTPS so you may need to disable it and try again.
