Midvintersorg
Aug 30, 2018Guide
Can't hear voicechat in FIFA and NHL
Hi!
I bought this awesome router. I have a little problem. When I play NHL and FIFA on Playstation 4 I can't hear voicechat in game, partychat works flawless but not in game voice. Any clues?
Netduma-Fraser
Aug 30, 2018NetDuma Partner
Are you connecting to a server or a peer when playing? If server then the peer may be outside your radius which is why it's not working.
- MidvintersorgAug 30, 2018Guide
It's p2p so the people I met are in the radius. I have upnp enable, sip-alg disabled and the nat-settings are open.
- Netduma-FraserAug 30, 2018NetDuma PartnerEnable SIP-ALG and see if that resolves the issue. It's also possible that they're not using the mic
