overbet
Jul 11, 2019Tutor
Cant locate access control for Nighthawk xr500
Where can I disable any new devices from connecting in the XR500 DumaOS? Every netgear router Ive ever owned had this feature, but I cant locate it on this router. Appreciate any help.
1 Reply
- Netduma-FraserNetDuma PartnerThis feature isn't available on the XR500, if you want to block devices you would need to do so via the Device Manager.
