IXIKaGeIXI
Apr 27, 2025Follower
cant loging to to router site keep taking me to adamn password reset
everytime i go to login to routerlogin.net or when i just use the routers ip itll tell me to type in my admin info and when i do it makes me reset it so i try it makes me go through security question...
Netduma-Fraser
Apr 27, 2025NetDuma Partner
The default credentials are admin / password so I'd suggest factory resetting, going through the setup wizard again, if you're using a password with symbols it may not work so keep it simple. Make a note of the details and then try to login again when changed - it is case sensitive.
