Datawolf79
Apr 27, 2020Follower
Can't open/forward ports
XR500 Dosen't seem to open/forward ports My network layout: Internet (COX) Modem Router (with the following attached) Server 192.168.1.11 (WIFI 5GHz) Gaming PC 1 192.168.1.5 (Ethernet) Gami...
Apr 27, 2020Guru - Experienced User
uPnP needs to be disabled if you are using PF configurations.
Netduma-Fraser
Apr 28, 2020NetDuma Partner
You're using three methods to open ports which will lead to conflicts. I'd suggest disabling port forwarding first and seeing if that fixes it as if you've put these in wrong that will also cause issues.
