Fremad
Jun 24, 2018Aspirant
Cant ser hosts, Wien using geofilter
Hi there
just installer my new router
cant see Andy hosts in geofilter
(pc)
regsrds Derek
Fremad
Devise type, Xbox where do i change it ?
Netduma-Fraser
Jun 24, 2018NetDuma Partner
Change it in the device manager
- FremadJun 25, 2018Aspirant
Sorry..
Just dosent work..
hopefully Netgear is aware of the problem. I know i am not the only one that has this problem.
Lets hope there soon comes af valid update for
PC users....suck
regards Derek
- Netduma_JackJun 25, 2018NetDuma Partner
Hi Derek,
Please do exactly this:
1. On your Geo-filter, delete any devices you added at the top
2. Go to Device Manager
3. Click on your PC on the Network Map
4. In the new panel that opens on the right, change the device type to an Xbox
5. Now go back to the Geo-Filter and add your PC.
6. Set the mode to Spectating Mode
7. Now try to play a game. Can you see the icons appearing once you are in a game?
Thanks
Hi again
trid to set it to Xbox but no luck
