deeken
Jun 08, 2020Aspirant
Can't setup Google home on XR700 — Nighthawk Pro Gaming Router
Hi, I can't setup my Google home. I am able to start the setup steps to connect my Google home to my wifi network, it finds it and each time makes it to the final setup step and fails, on the Goo...
Netduma-Fraser
Jun 09, 2020NetDuma Partner
In wireless settings disable Smart Connect and try to detect it to either 2.4 or 5GHz and see if that resolves it.
- deekenJun 09, 2020Aspirant
I actually did a factory reset on my Google home devices and that worked, It seems they kept some sort of connection to the old router setup even when removed and re-installed.
Thanks for your response.
