Andyj986
Mar 10, 2019Follower
Can't unblock a device
Hi all, I purchased you Nighthawk XR700 router. I’m quite happy with it except for one issue. I’m experiencing only one major issue with it, I think it may be more of a DumaOS software issue. ...
Netduma-Fraser
Aug 11, 2019NetDuma Partner
I've responded to you on the Netduma forum but What happens when you try to unblock the device via the app or via the interface?
CyberGator
Aug 11, 2019Aspirant
The app or the website show the unblock as successful and Saved, but it doesn’t work.
