mhdavid87
Jun 04, 2021Aspirant
Certain types of traffic being blocked between Wired and Wireless Connections
Hello All, I am having some issues with my XR500. Certain types of traffic is being blocked and not working as it should between wired and wireless connections. For example; 1. RDP (3...
mhdavid87
This also seems to be a common issue.
I should have purchased a router with simple features, this doesn't really make any sense as to why crap is blocked between wired/wireless connections. It is a stupid feature whatever is blocking it.
Netduma-Fraser
Jun 04, 2021NetDuma Partner
On the beta version you could try allowing ALL traffic from each of those devices, that should in theory bypass any potential blocks that are occurring
- mhdavid87Jun 04, 2021Aspirant
Where abouts in the interface can I set that?
- Netduma-FraserJun 04, 2021NetDuma PartnerYou can download the beta version from here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR500/td-p/2071196/ once upgraded you'll have the Traffic Controller option to try that
I have literally set everything to allow all traffic, no good mate.
Any other ideas?
This is becoming fairly frustrating for something that should just work.
I think I'll be taking this back for a full refund if I don't have this resolved as soon as possible.
