mhdavid87
Jun 04, 2021Aspirant
Certain types of traffic being blocked between Wired and Wireless Connections
Hello All, I am having some issues with my XR500. Certain types of traffic is being blocked and not working as it should between wired and wireless connections. For example; 1. RDP (3...
Netduma-Fraser
Jun 04, 2021NetDuma Partner
On the beta version you could try allowing ALL traffic from each of those devices, that should in theory bypass any potential blocks that are occurring
mhdavid87
Where abouts in the interface can I set that?
- Netduma-FraserJun 04, 2021NetDuma PartnerYou can download the beta version from here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR500/td-p/2071196/ once upgraded you'll have the Traffic Controller option to try that
- mhdavid87Jun 04, 2021Aspirant
I have literally set everything to allow all traffic, no good mate.
Any other ideas?
This is becoming fairly frustrating for something that should just work.
I think I'll be taking this back for a full refund if I don't have this resolved as soon as possible.
Ok, so this issue seems to be directly tied into the fact that I need to enable a 'VLAN' tag for my internet to work over PPPoE.
Automatically it selects all Wired and Wireless ports.
Why would this be blocking traffic between my Wired and Wireless connections?
It makes no sense, I am getting to the end of my wits!!!
- Netduma-FraserJun 05, 2021NetDuma PartnerTry disabling the VLAN that it defaults to, make a new one but don't select any of the ports/WiFi, does that allow you to keep an internet connection and for your devices to communicate with each other?
