Russ73
Dec 03, 2022Aspirant
Changing BT hub to XR1000
Hi I have spent all morning trying to set up my new XR1000. My ISP is BT and I was using their Home Hub. Once I set up my XR1000 it comes up " No Internet Connection" I was wondering do I need any ...
Russ73
I am going straight from BT ONT to the Netgear
Netduma-Fraser
Dec 03, 2022NetDuma Partner
You'll need to check the hub network settings to see if there is anything you need to put in the XR
