spicycarlos14
Nov 01, 2019Follower
Cisco Any Connect Not working with XR500
Once I switched to the nighthawk xr500, my wifes computer with cisco any connect wont connect at all. I reset factory settings, turned off QoS and everything else. whats the work around here
Netduma_Alex
Nov 05, 2019NetDuma Partner
Make sure UPnP is turned on, also disable SIP ALG, that can interfere with applications like anyconnect.
