jeremyg237's avatar
jeremyg237
Luminary
May 22, 2018
CISCO webex hogging bandwidth
My wife does Cisco webex for college and latley its crashing or hogging all the interenet even though I hace the anti bufferbloat set. Need a little help ont this one. Should I uncheck WMM. Never had this issue before becuase she just started using it.
  • Keep WMM enabled. For Anti-Bufferbloat as above is it set to Always? Have you lowered the sliders to the recommended 70%? If you leave it at 100% it will be like it is disabled.
    • jeremyg237's avatar
      jeremyg237
      Luminary
      My setting for anti-bufferbloat is:
      70% and when high priorty traffic is detected
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Change it to Always otherwise it won't apply it unless games are being played.
