Christiaan11
Sep 29, 2022Apprentice
Cluttered network overview
Hi, On the DUMA Network overview page of my XR1000 the page gets more cluttered every day. Seems like a lot of "unnamed" devices that change IP after a while keep showing up in the overview makin...
- Sep 29, 2022
Are you using mac or iOS devices? their private mac/ip address feature can add a lot of "un-named" devices because its creates new ones to randomize it. You can disable that on the mac iOS device
Sep 29, 2022Guru - Experienced User
- Christiaan11Sep 29, 2022Apprentice
ah, that makes sense indeed. We do have some apple devices indeed. I'm not sure though if I would like to turn this functionality off. Is there a way to hide or automatically remove them from the interface? Are you aware of any options?
Thanks for the help!
- plemansSep 29, 2022Guru - Experienced User
Netduma-Liam would have a better idea if you can remove them from the interface. I don't have any of the DumaOS devices.
In terms of leaving it enabled, you'll continue to get more added if its enabled. And you really don't need it enabled at home. Its more when you're in public where you might have privacy/security concerns.
- Netduma-FraserSep 29, 2022NetDuma PartnerNot automatically but if you click the 3 horizontal line icon on the Device Manager you can remove offline devices
Thanks. Not ideal but will do for now. Maybe good to add a feature request to have the option to group. I see there is also an option to remove all offline devices but that would remove all settings (incl things like geo filter for game devices I assume).
