MRowe
May 01, 2019Guide
COD BO4 Multiplayer Issue
Hi, Since couple of weeks, I can not play with any Call of Duty Game (BO4, WW2, etc.) It says no connection with COD servers. I checked it from PC, PS4, XBOX, the problem is the same, can't connect...
May 24, 2019Guru - Experienced User
Has a factory reset and setup from scratch and walk thru the setup wizard on the XR router been performed yet?
MRowe wrote:Hi,
I checked it from PC, PS4, XBOX, the problem is the same, can't connect to COD servers.
I have a long discussion with Activision and my ISP, I check / set everything they asked to do (Ports etc.)
I have a netgear cable modem from ISP connected to my Netgear Nighthawk XR500. If I use ISP netgear cable modem for Black Ops 4 or any Call of Duty, It is working, but if normally wnat use these COD games through my XR500 it is not working.
I have checked XR500 DumaOS setting for Call of Duty.. nothing helps.
Can you please help me with this weird things... only call of duty can not work on my XR500 router, battlefield and everything is OK
Please, give a good solution.!
Thanks
MRowe
May 24, 2019Guide
Yes, my XR500 connected to NETGEAR C6250EMR ISP cable modem.
Yes, as it was proposedI did , several times.
- FURRYe38May 24, 2019Guru - Experienced User
Your model already has a built in router and wifi. Is the modem bridged?
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.- MRoweMay 24, 2019Guide
There are options in ISP modem:
1.) Non Router Mode - I am using this, This is the Bridge Mode and ISP proposed to use this, WIFI is disabled.
2.) RouterMode - I used this, but not worked, and I want my XR500 to do the router things
I have already done, tried this before.
There was just a simple logical question in my mind, the other borrowed router why can handle this?- FURRYe38May 24, 2019Guru - Experienced User
If the C modem is fully bridged then the XR should and will be handling all router operations and CoD games should work well. Unless there is a misconfiguration with the XR router.
Does a different router connected to the C modem work for CoD?
