SonnyLewisDmnd
Jun 28, 2018Guide
cod ww2 settings
hi all,looking for any other settings for ps4 to help maybe cut back latency during onling multiplayer for cod ww2 just i'm finding 6 out of 10 games i get alot of latency[hit registration]
is rea...
- Jun 28, 201820ms is a VERY good ping. I would remove the manual addition of your PS4 from Traffic Prioritization as if DumaOS Classified Games is enabled it will prioritize the console by default. I think there may be 2 servers in Australia if I remember correctly so you could try to force the other one. You could also experiment with different Anti-Bufferbloat percentages to see what gives you the best experience.
Netduma-Fraser
Jun 28, 2018NetDuma Partner
SonnyLewisDmnd
Jun 28, 2018Guide
ok cool appreciate your response
- FaulkoJul 03, 2018Aspirant
There is only 1 dedi center for PSN and cod and thats in Sydney.
Xbox has 2, first in sydney, 2nd in adelaide.
COD still uses a hybrid netcode where not all players in a lobby are connected to the server, its random but certain player can and do peer for other players.
In Aus you will always be put in a lobby thats full of people as wide as NZ to perth and as low as Tas to as high as Japan and everywhere inbetween.
Nothing you can do other then leave that lobby and try another 1.
