m00shue
Mar 09, 2020Aspirant
Company VPN connection keeps dropping since at least last 2 firmware updates
2 of us work from home using company VPN I can conect fine from my wired Windows 10 PC through Cisco Anyconnect as do my wireless devices using the same XR500 Gaming router. 1 Windows 10 lapt...
m00shue
Correct, disabled anti buffer in QoS setting but had no affect either way.
Current setting to 80%. We do a lot of streaming and don't really have any noticeable effect on gaming
No devices in geo-filter.
Not using vlan, ppoe, or ipv6.
Just changed the wan setting to disable SIP ALG and unchecked disable IGMP Proxying.
Netduma-Fraser
Mar 09, 2020NetDuma Partner
No difference after changing the WAN Settings? Could you try setting up a guest WiFi network and see if when connected to that it works please?
- m00shueMar 10, 2020Aspirant
No difference with any of the changes.
We do have a guest wifi set up. Same result as both 2.4 and 5ghz connections as well as wired. No connection route lets the vpn client connect. It actually will not even establish a connection at all now.
Jump to a mobile hotspot and it goes right through as well as bypassing router direct to modem.
- Netduma-FraserMar 10, 2020NetDuma PartnerI can't think of anything settings wise that would be causing this, I'd suggest making a ticket directly with NG as they may have encountered this before http://support.netgear.com/
Kind of thought I was contacting support right here.
The router was purchased at the end of 2018 after paying for support on a previous router was unable to solve the intermittet connection issues of all devices preventing us from working efficiently.
We purchased this new router in hopes I could manipulate traffic a bit more to give us priority over gaming and streaming devices. Now less than 2 years later, cannot even establish a VPN connection. An incredibly common feature that should not be broken in any networking device.
Contemplating just buying a nice Cisco ASA and call it a decade. Rock solid!
Surely someone from netgear reads these forums and is able to provide some type of support for existing customers without having to cough up yet more money.
