Von420
May 26, 2020Follower
Compatible with optimum?
Does anyone know if the Nighthawk Pro Gaming XR700 compatible with optimum?
May 26, 2020Guru - Experienced User
Any router is compatible with a modem or gateway modem. ISP specific services are not a factor. Stand alone modems are preferred for use with any external router.
- Netduma-FraserMay 26, 2020NetDuma PartnerAs above, you should have no problem with this ISP and the router.
