Anonymous's avatar
Anonymous
Aug 20, 2018
Computer(s) IP Address changes on Computer reboot?
I bought this Netgear router yesterday. I love the NetDuma OS so far. I am coming from an ASUS AC88U which I have used for a couple of years. One question that I have is this.   Every time I rebo...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Aug 21, 2018
    This is expected behaviour, allbeit a bit frequent than one would expect. As you're using DHCP the IP isn't strictly just for that device so by turning a device off that IP is now available for another device to pick it up. This isn't an issue as it's not causing you any issues and if you want it to stop changing then you can just set a static IP address.
