David1972's avatar
May 10, 2021
Conexion fuera de mi region
Buenos dias,
llevo unos dias probando el xr500 y en general va bien pero al intentar conectar con Sud America, India y Australia es imposible conectar habiendo servidores y saliendo marcados en el router.
Si intento conectar en EEUU no hay problema.
La version que tengo instalada es la beta.
Alguien sabe porque puede ser??
Gracias
David
1 Reply
  • Hey David,
    Where abouts are you actually located? If these servers you're trying to connect to are Geo-graphically very distant from you, you may find extensive wait times or that you're simply unable to connect. This is more down to most games' matchmaking process rather than something DumaOS can control.
