aaronibm21
Nov 16, 2021Luminary
Configuracion optima para xr500 WARZONE
Buenos dias compañeros, alguien tiene el router xr500 optimizado para jugar a Warzone o Vanguard ?? que configuracion usais en Qos?? Gracias a todos.
Nov 17, 2021Guru - Experienced User
In inglese per favore
aaronibm21
Nov 17, 2021Luminary
Actualmente tengo instalada la versión 2.3.2.130 , me ha solucionado problemas como raps que no cargaban y problemas de wifi, todo eso esta ok ahora, me interesaria saber la mejor configuracion Qos para mi router y que no me tire la red abajo. Tengo la compañia Digi es el modelo H298Q de ZTE con fibra 1gb simetrico. conectado al router xr500 en la boca 1 del router Digi , con el Dmz Host a la ip del router xr500 .
I currently have version 2.3.2.130 installed, it has solved problems such as raps that did not load and Wi-Fi problems, all that is ok now, I would be interested to know the best Qos configuration for my router and not to throw the network down. I have the company Digi is the ZTE model H298Q with 1gb symmetric fiber. connected to the xr500 router in port 1 of the Digi router, with the Dmz Host to the ip of the xr500 router.
- FURRYe38Nov 17, 2021Guru - Experienced User
I have my QoS bandwidth sliders set for 99% since I'm the only one on my XR450 that games. If you have others on the router at the same time you game then you might try 70% on the sliders.
