One1go's avatar
One1go
Guide
Apr 17, 2020
Configuration for Movistar Triple VLan (Internet, VoIP, IPTV)
Hello
I have bought this router for the Geo-filter functionality which I think is very interesting.  I have Movistar Fusion which uses triple VLAN setup for services.  I have this workin perfectly on my ASUS RT-AC88U (it was really easy too!) But I can only get the Internet Connection working, and VoIP and IPTV do not work.  I have tried every possible setting in the VLAN Tag/Bridge Group menu with no luck... Anyone has sucessfully gotten this configuration working?   Thanks!
  • michaelkenward's avatar
    michaelkenward
    You might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
    Nighthawk Pro Gaming Routers - NETGEAR Communities
    No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
    I have asked the Netgear moderator to move your message.
    If you visit the support pages:
    Support | NETGEAR
    you can feed in your model number and find the documentation for your hardware.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Have you set specific VLAN Settings for the connection method they're using e.g. 2.4 or 5GHz WiFi or the specific port? Also in WAN Settings untick Disable IGMP Proxying and tick to disable SIP ALG.
      • One1go's avatar
        One1go
        Guide
        Yes I set the specific VLAN.  I didn't try disabling IGMP proxying or SIP ALG, I will try with that and see what happens, thanks.
