P111
Oct 15, 2018Luminary
Confused on what to buy
I have a VDSL connection. I currently use a good six port router with a built in modem. The only problem is that its a commercial unit and its very complicated. I would like to replace it with perhap...
Nov 15, 2018Guru - Experienced User
You can add any kind of switch to a modem/router combo or router unit. Even if the ports are limited on the modem router, you can just add a network switch. I have 24port on my system along with several other switches sprinkled around the house.
It's up to you what you need. Do you do alot of gaming or just here and there, If alot, then maybe a XR router would work. If your just a causual gamer, then maybe just the modem router combo is all you need.
