Kippa44
Aug 09, 2021Aspirant
connect XR500 router on web browser
I cannot connect into the router so that i can port forward
Kippa44
I used to be able to see all the connections on my PC and be able to mange them. Now all that is available is the downloaded app?? why has this altered?
antinode
Aug 09, 2021Guru
> mange them. [...]
That's nice, but with my weak psychic powers, I can't see what you
did then any better than I can see what you're doing now.
> [...] Now all that is available is the downloaded app?? [...]
Says who? Visit http://netgear.com/support , put in your model
number, and look for Documentation. Get the User Manual (at least).
Read. Look for "Use a Web Browser to Access the Router". Further
reading might not hurt, either.
> [...] why has this altered?
I see no evidence that anything has changed, only a bunch of vague
assertions that some invisible thing doesn't work in some unspecified
way. Hence the requests for some actual information. Which part of
"not a useful problem description" or "actual" did you find unclear?
- Kippa44Aug 09, 2021Aspirant
that's my problem my web browsers will not access the router.
- antinodeAug 09, 2021Guru
I disagree. Your primary problem seems to be that you are unable to
provide a useful problem description. Regarding "will not", see "not a
useful problem description [...]", above.> I see no evidence that anything has changed, only a bunch of vague
> "not a useful problem description" or "actual" did you find unclear?Read it again?
- Kippa44Aug 10, 2021Aspirant
I am not being clear see below instructions from support, when i enter routerlogin.net or http://192.168.1.1 in my browser that is loggin=ed into my network provider. It does not go any further....
log in to your NETGEAR router with a web browser:
- Launch a web browser from a device that is connected to your router's network.
- Enter routerlogin.net or http://192.168.1.1 in the address bar.
The router login window displays.
