lcarr0824
Mar 28, 2020Aspirant
Connecting an AC1200 to an R6700 as an AP
I own an R6700 router. I live in a 2000+ sq ft home and I have dead spots in my home. I want to mount my R6700 in my smart control panel in my master bedroom closet. I want my SmartTV in the living r...
lcarr0824
This is lcarr0824 again ... and I forgot to mention that I would like the two AC1200 routers to allow me to connect to the same SSIDs that my R6700 propgates.
Louis
- plemansMar 29, 2020Guru - Experienced User
I'd recommend going the route of orbi and not trying to rig something up. You might get it working but it could be a constant headache to fight with.
you can set the ssid's the same using the AC1200's but its not a mesh system as nothings controlling it so devices will tend to be sticky.
You'll also gain band steering/single ssid function with orbi.
If you watch amazon, they've been running deals on renewed/refurbished orbi systems.
