babybypug
Jun 05, 2023Guide
Connecting the expressvpn aircove to my netgear xr700 possibe??
Trying to connect my Comcast router in bridge mode to my Netgear router and My new Expressvpn Aircove I was wondering is it possible since i already set up rules for my netgear for port forwardi...
Netduma-Fraser
Jun 06, 2023NetDuma Partner
Probably best to go with the first setup so you can put the XR in the VPN, your ping will increase using a VPN and you'll be unlikely to get an OpenNAT as well.
- babybypugJun 06, 2023Guide
Thanks again glad it's working .
