babybypug
Jun 05, 2023Guide
Connecting the expressvpn aircove to my netgear xr700 possibe??
Trying to connect my Comcast router in bridge mode to my Netgear router and My new Expressvpn Aircove I was wondering is it possible since i already set up rules for my netgear for port forwardi...
Jun 06, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
babybypug
Jun 06, 2023Guide
Thank's for the in took 2 weeks of trying to figure out when my called express support. Which they said comast-netgear-aircove that didn't work at all I finally figured out that I need to separate the 2 computers all together. comcast - aircove - work pc, aircov second port ethernet connected to my netgear but setup as novpn grouping so it dosen't block port forwarding for my games . So far working great. Thanks again.
