SlayerPro
Apr 08, 2019Aspirant
Connection Dies Randomly With QoS Enabled
I am having a weird issue with my Nighthawk X500 Router. With QoS enabled, the connection will drop randomly. When this happens, I can play with the QoS slider and the connection will come back for a...
Netduma_Jack
Apr 09, 2019NetDuma Partner
Hi there - this is very unusual. What mode is your Anti-Bufferbloat set to when these drops occur?
What is your total bandwidth? How much are you reducing the sliders to?
- SlayerProApr 09, 2019Aspirant
450/30
80%
XR500 V2.3.2.40
Arris TM1602 Cable Modem
- Netduma-FraserApr 09, 2019NetDuma PartnerWhat's your physical setup, modem > XR500 > switch etc? Do you use PPPoE or VLAN?
Cable Modem to Router. One PC plugged into router. Everything else is wireless.
No PPPoE or VLAN.
