Ballbag69's avatar
Ballbag69
Initiate
Jan 22, 2023
Connection issues XR1000 NightHawk
Hi,
I am trying to play Back 4 Blood on my PC. No matter what I do, I can't connect to any match - it just throws me back into the lobby and asks if I would like to try and reconnect. My last variable that I can think of is an issue with the router itself not allowing me any connections to the game.
I've tried a wired connection, a WiFi connection, reinstalling the game, restarting my pc and router. I even tried disabling IPv6 hoping it would help but nothing worked. I was trying it via game pass for PC and gave up and bought the Steam edition hoping that might have even helped. Nope, still got the same issue.
I used to play this on my Series X before I had the NightHawk router, so I'm wondering if it's the router that is giving me the grief.
Cheers.
  • michaelkenward's avatar
    michaelkenward
    The XR1000 isn't one of your conventional Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers.
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Nighthawk Pro Gaming Routers - NETGEAR Communities
    Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
