Ballbag69
Jan 22, 2023Initiate
Connection issues XR1000 NightHawk
Hi, I am trying to play Back 4 Blood on my PC. No matter what I do, I can't connect to any match - it just throws me back into the lobby and asks if I would like to try and reconnect. My last vari...
Ballbag69
Jan 23, 2023Initiate
Got it sorted.
Went back to my ISP supplied router and I’m no longer having any issues connecting. In fact I’m also hitting higher download speeds. Been having nothing but trouble with this router since I bought it. Will be returning it. Absolute dog water.
Netduma-Fraser
Jan 23, 2023NetDuma Partner
Most likely the cause was the Geo-Filter being enabled, if you disable that I suspect it would work. If you want to give it another go let us know and we'll be happy to help.
