Evanfly
Nov 04, 2020Guide
Connection issues XR500
Hi new member here could someone please give me any advice on the following my XR500 is dropping wifi quite frequently(both 2.4 & 5) I have factory reset it (f/w v2.3.2.66) but still the issues remai...
Nov 04, 2020Guru - Experienced User
Is Smart Connect enabled?
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM.
Netduma-Fraser
Nov 04, 2020NetDuma Partner
Sounds like you have Smart Connect disabled, is that the case? Use a WiFi analyzer to find the least congested channels and change to those.
