XxGRIM
Apr 29, 2020Star
Connection loss
Apr 30, 2020Guru - Experienced User
Modem its connecting to?
Firmware on the xr500?
What speeds do you pay for?
What speed do you get hardwired to the xr500?
Netduma-Fraser
Apr 30, 2020NetDuma Partner
If you could answer the above questions that will definitely help us help you. Also are you using QoS and the Geo-Filter? If so what settings are you using?
- XxGRIMApr 30, 2020StarYeah I have them both on. For the geo filter I have it set at 1448 miles, however it’s not on my state. I have it at the center of the country, that way I can play with others. For the QOS I have all devices evened out at 8 up and download. I have anti buffer boat on always and have the both the sliders at 100%
- geekywindowsMay 01, 2020Aspirant
If you want to know How to incrase uplode and and download speed this go hear
- XxGRIMMay 01, 2020StarAlright, will try, thanks.
- plemansMay 01, 2020Guru - Experienced User
The MT7711 is a modem router combo device. do you have it in bridge mode?
otherwise you're in a double nat as well as the mt7711 could be slowing speeds/causing issues.
- Netduma-FraserMay 01, 2020NetDuma PartnerI'd recommend you first run through our optimal settings guides here and see if you see an improvement after that: http://support.netduma.com/en/support/solutions/folders/16000090646 good suggestion above also.
