XxGRIM
Apr 29, 2020Star
Connection loss
May 01, 2020Guru - Experienced User
The MT7711 is a modem router combo device. do you have it in bridge mode?
otherwise you're in a double nat as well as the mt7711 could be slowing speeds/causing issues.
XxGRIM
May 01, 2020Star
No I don’t, I’ve tried to put it in bridge mode before. Right now I don’t have them in bridge mode however. I’ll have to try it again, how would I know that it’s in bridge mode?
- Netduma-FraserMay 01, 2020NetDuma PartnerThe link plemans provided shows where you can find the option to see if it is enabled.
- XxGRIMMay 01, 2020StarAlright, I’ll get on it as soon as I get the time. Will let you guys know.
- XxGRIMMay 02, 2020StarAlright so Ive tried to put it in bridge mode, however it doesn’t allow me. I select to put the eRouter Provisioning Mode in “bridge” mode but when I go log in, it’s set as back as default which is “eRoute_DualMode”
