SouthernGypsy
Aug 30, 2024Apprentice
Connection Test Failes to Give Results
I have our XR1000v2 set ro run a scheduled test every two hours and was working fine, let me monitor the connection over time. But for going on a week now the Speed Test and Ping Test (Under Load) fa...
Aug 30, 2024Guru - Experienced User
Post a screen capture of this please?
What browser are you using?
- SouthernGypsyAug 30, 2024Apprentice
I'm using Firefox (newest version) but don't see what difference that would make, the browers is not loaded when the XR1000v2 is running most of these tests, except when I run one manually but the result is the same.
I just cleared all the test off earlier (keep in mind these do not show failed, yet they show no results in many of the fields) but here is the last few it's done plus a couple of manual ones I just did....
- Netduma-FraserAug 31, 2024NetDuma PartnerHas anything changed physically with your setup or settings wise prior to the issue happening?
- SouthernGypsySep 01, 2024Apprentice
No, everything has been the same for weeks. Just slowy it now looks like that every test. It started out where only a test every now and then would do it, then every few tests, and now EVERY test. Yet I have not changed any settings at all.
Rebooting or Power Cycling the router does not help either.
