SouthernGypsy
Aug 30, 2024Apprentice
Connection Test Failes to Give Results
I have our XR1000v2 set ro run a scheduled test every two hours and was working fine, let me monitor the connection over time. But for going on a week now the Speed Test and Ping Test (Under Load) fa...
SouthernGypsy
I'm using Firefox (newest version) but don't see what difference that would make, the browers is not loaded when the XR1000v2 is running most of these tests, except when I run one manually but the result is the same.
I just cleared all the test off earlier (keep in mind these do not show failed, yet they show no results in many of the fields) but here is the last few it's done plus a couple of manual ones I just did....
Netduma-Fraser
Aug 31, 2024NetDuma Partner
Has anything changed physically with your setup or settings wise prior to the issue happening?
- SouthernGypsySep 01, 2024Apprentice
No, everything has been the same for weeks. Just slowy it now looks like that every test. It started out where only a test every now and then would do it, then every few tests, and now EVERY test. Yet I have not changed any settings at all.
Rebooting or Power Cycling the router does not help either.
- Netduma-FraserSep 02, 2024NetDuma PartnerI'd be tempted to say it's the hardcoded server address that is out of date, however, I believe the ping portions actually use the google servers so I don't think that tracks. So it seems more likely that these connections are being blocked in some way. What is the model of the modem/router the XR is connected to and how have you set that to ensure all traffic flows to the XR? E.g. XR in its DMZ, modem/bridge mode.
