Dracolyte
Aug 24, 2018Follower
Connection
i have a computer and a xbox one x maybe 30 feet from the wifi router RX500 nighthawk with a wifi booster connected maybe 5 feet from it to boost the signal which gives me 200-250 mbps of download an...
Aug 24, 2018Guru - Experienced User
You have an extender 5 feet away from the XR router?
What channels are you using? Auto? Try manual channels 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Try disabling MIMO. Then try disabling Smart Connect.
Try with out the extender and see if the same problem happens?
