Dracolyte
Aug 24, 2018Follower
Connection
i have a computer and a xbox one x maybe 30 feet from the wifi router RX500 nighthawk with a wifi booster connected maybe 5 feet from it to boost the signal which gives me 200-250 mbps of download an...
Aug 24, 2018Guru - Experienced User
You have an extender 5 feet away from the XR router?
What channels are you using? Auto? Try manual channels 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Try disabling MIMO. Then try disabling Smart Connect.
Try with out the extender and see if the same problem happens?
Netduma_Jack
Aug 25, 2018NetDuma Partner
Hi OP - I would try furry’s great advice. Especially consider taking the extender out of your network. The XR500 has very powerful wireless so you shouldn’t really need an extender given it’s so close to your router. It’s effectively obsolete now.
