Sir_headcase
Nov 01, 2019Follower
Connections problems XR500
My internet connections keep dropping with my XR500. I first thought it was my service, so I got a new modem had them come out and after all that I only hooked up to my modem and have 115mbps. But whe...
Netduma-Fraser
Nov 02, 2019NetDuma Partner
So this is an actual issue of the XR500 not connecting properly to the modem rather than any devices specifically? Since you've got the new modem did you factory reset the XR500 and run through the setup wizard from scratch?
