Turboamerica
May 18, 2020Aspirant
Constant ack port scan dos attacks Xr700 nighthawk
To begin with,everyone stay safe and healthy. I have an xr700 nighthawk gaming router,ordered especially new from Germany,as I wasn’t able to purchase it in Russia. For some time I’ve been getting so...
Netduma-Fraser
May 19, 2020NetDuma Partner
The router isn't performing DoS attacks on you, it's unfortunately worded - it is just showing IP addresses/connections you have come in contact with. It is highly unlikely they are causing your issues.
What speeds do you pay for/what do you get direct to the modem? What speed does it drop to? What is your average ping to the game as shown by the Geo-Filter?
- TurboamericaMay 19, 2020AspirantSo I pay for 1gb/S
My pc gets around 900mb/S while being wired to Ethernet without router
And it won’t drop anywhere
My router sees the speed at exactly 1gb/S
When this happens,my speed drops to around 100/60 constantly. May get to 40/30 and packet loss - TurboamericaMay 19, 2020AspirantSorry for the 2 reply,I don’t know how to edit,kinda a new user here
My ping doesn’t change. It’s around 10-20 on moscow servers and around 60 Germany
Also tested my ISP router(like a 20$ crappy one) and it has constant 400+mb/S no drops nothing- Netduma-FraserMay 19, 2020NetDuma PartnerHow often is the speed dropping? Does it occur on all devices? That ping is really good so must be related to the speed drop.
- TurboamericaMay 19, 2020Aspirant30 seconds after my router boots up the speed is reduced. On pc and iPhone for sure. Ps4 speeds are on a bad server,so I ignore them+my ethernet cable connected to ps4 is a little messy.
And yea,I tried using and turning off QOS. No difference. Also for some time now getting SKIPED SPIKE RTT on my router
