Turboamerica
May 18, 2020Aspirant
Constant ack port scan dos attacks Xr700 nighthawk
To begin with,everyone stay safe and healthy. I have an xr700 nighthawk gaming router,ordered especially new from Germany,as I wasn’t able to purchase it in Russia. For some time I’ve been getting so...
Turboamerica
May 19, 2020Aspirant
Sorry for the 2 reply,I don’t know how to edit,kinda a new user here
My ping doesn’t change. It’s around 10-20 on moscow servers and around 60 Germany
Also tested my ISP router(like a 20$ crappy one) and it has constant 400+mb/S no drops nothing
Netduma-Fraser
May 19, 2020NetDuma Partner
How often is the speed dropping? Does it occur on all devices? That ping is really good so must be related to the speed drop.
- TurboamericaMay 19, 2020Aspirant30 seconds after my router boots up the speed is reduced. On pc and iPhone for sure. Ps4 speeds are on a bad server,so I ignore them+my ethernet cable connected to ps4 is a little messy.
And yea,I tried using and turning off QOS. No difference. Also for some time now getting SKIPED SPIKE RTT on my router- Netduma-FraserMay 20, 2020NetDuma PartnerThat doesn't make any sense, do you have new ethernet cables you can connect the XR to the ISP modem/router and to connect to your PC?
- TurboamericaMay 20, 2020Aspirant
shame I do not have the ISP modem, my lease period ended like a month ago. also a upd on logs-my inet started dropping to 50/30 speed and 1-3% packet loss. the logs are all full of port scans from google etc( so not a real dos attack), also constant rtt skiped spike. restarted the router and speeds back to 160/70 and no packet loss. i really just cant get my thoughts on whats wrong whith it.
