cheese83
Mar 19, 2020Aspirant
Constant DHCP Lease Changes
Lately my router has been constantly changing the DHCP lease per the router logs and it appears to cause me to drop connectivity in game. Literally can't play Fifa online right now because of constan...
cheese83
My xbox is connected directly to the router and had a static/reserved IP, actually just deleted the connection to see if it would improve things. It did not.
Netduma-Fraser
Mar 19, 2020NetDuma Partner
Are any other devices dropping the connection or is it just the device you're playing FIFA on? Wired & wireless devices?
- cheese83Mar 19, 2020Aspirant
They're pausing slightly just like the lag in COD, but Fifa kicks me out of the match. Usually lasts about 10-20 seconds.
- Netduma-FraserMar 19, 2020NetDuma PartnerAre you using the Geo-Filter for FIFA? If so disable it and see if that makes a difference. Also are the devices affected on WiFi?
I was not using Geo-Filter. The devices were directly connected and wifi, did not seem to make a difference.
